Furlers are the way to go
E
Eric
Several months ago I solicited some advice on this forum for purchasing a furler. I ended up buying a CDI FF4 from Cruising Direct Sails, and after sailing with it several times now I can honestly say that this is by far the best investment I have made in my sailboat to date. If anyone reading this is considering buying a furler, do it! You won't regret it. You can get a good furler for $500 or less, and if you already have a genoa jib that's in good shape you can easily get it modified by a local shop to fit your furler. If you're a relative novice like myself, you may need to hire an expert to install the furler, and this could end up costing you another $200 or so (after watching mine installed, I realized I could never have done it myself). Bottom line is that for an investment of less than $1000 you could easily double or triple your sailing enjoyment for some time to come.
E
Eric
Mike
Amen
I couldn't agree more. I put the same model furler as you have on my Oday 23 a couple of years ago, and I can't believe I went so long without one.
Mike
Amen
Jun 1, 2004
15
Oday 23 Brookville Lake, Indiana
Same Model?
Mike, When you say you "put the same model furler" on your O23 do you mean the FF4 or just that it was a CDI system? I'm looking at a furler for my O23 and I understood that CDI recommends the FF2. I'd be interested why you went with the larger unit if that is what you did.
Jun 1, 2004
15
Same Model?
Mike
Its embarrassing
I can't remember which size I went with. I thought it was the FF4, but it might have been the FF2. I do remember it was the size that Rudy at D&R Marine had recommended for the 23. I bought it from my local sailmaker, who matched the best internet price I could find. Its a great unit.
Mike
Its embarrassing
E
Eric
Furler Size
Chris, I would recommend you go with whatever size CDI advises. I don't think the FF2 is of any lesser quality; it's just a different size furler for a different size boat. You CAN choose whether you want the ball-bearing model or not, and from what little I know it's worth the extra $50 or so. You should also shop around on the net for a good deal. I've posted the link where I bought mine.
E
Eric
Furler Size
bruce cornell
basic furler
furlers ARE the way to go, even on my javelin, replaced the forstay with a harken 435 system and wire luffed the jib for a one piece system. the boat may be only 14' but not having to go forward to handle the jib is worth every cent.
