Fuel Usage for Albin Vega equiped with diesel
Oct 30, 2019
13
I know it is a sailboat, but still need to know.
What has been the experience of Albin owners in regards to fuel burn
per hour and at what cursing speed was this rate?
thanks,
Keith
Oct 30, 2019
5
Hi!
As I´m new to this, other with more experience can have other results,
but when motoring my boat home I noticed following:
Enginge, Albin O22 gas engine, 0,4 lit/hour at a speed of 5 knots.
Cheers,
Tomas
Nov 19, 2005
9
During our last holiday we used our engine for about 25 hours at an average
of one liter (diesel or gasoil as you call it) per hour. Our average speed
at that time was between 4 and 6 knots.
Hope this helps.
Flor Oyen
Vega 566,
_____
Van: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] Namens
enigma.seti
Verzonden: dinsdag 15 augustus 2006 7:37
Aan: AlbinVega@yahoogroups.com
Onderwerp: [AlbinVega] Fuel Usage for Albin Vega equiped with diesel
thanks,
Keith
Oct 19, 2019
921
Albin Vega 27 Breakaway Limerick
I can't resist (see below): "cursing speed"!! Well named when engine is
giving trouble...
I do notice that when I run engine at full throttle - giving a speed in
flat water of about 6 knots, that consumption is very high. I haven't
quantified this yet.
Moral: keep revs down unless you are in a hurry..
John
Vega 1447 Breakaway
enigma.seti said in an email sent on 15/08/06 06:36 that:
Oct 31, 2019
562
My Vega V-257 is powered with a Yanmar 1GM10 Diesel and (at
calm sea) cruises at 6.5 m/h (5.7 knots/h), running at 3000
rpm and using about 1 US quart/h (0.95 liter/h)
Wilhelm, V-257
Oct 30, 2019
13
Thanks all for your feedback.
John, may I use the excuse that the keyboad letters never seem to
be in the same place twice? :)
huummm, but then maybe when a person is typing fast his real
thoughts tend to come to the surface unbidden.... :)
thanks,
keith
Nov 8, 2001
1,818
Hi All
Cruising revs you should get 1 litre per hour. Speed will be dependant
on conditions. Flats ea and no tides or winds should get 5 knots easily.
I have been down to a couple of knots when wind and tides conspire
against me!!
Cheers
Steve Birch (Technical)
Oct 30, 2019
58
Steve.
What size prop do you have on your Beta - Mine's a 12x8 but feel a 12x9
might be a better choice (I could be wrong), is there any one out there
with experience of this? A few weeks ago I motored at ~4.5-5 knots for
14 hours (not a breath of wind) on just over 10-12 litres of fuel.
Ray (Tortuga)
Ray Wilton
Ship and Field Support Manager
School of Ocean Science
University of Wales (Bangor)
Menai Bridge
Angelsey
LL59 5AB
Tel 01248 382614
Fax 01248 716367
Oct 31, 2019
19
I have a Yanmar 2GM with a 14 x 11 prop - Bit over powered but:
Full power at 7knts it uses 1.7 litres per hour
Cruising at 5 kts circa 2000 rpm it uses about .75 litre per hour
We cruise most of the time at 5 - 6 kts with ease. Recently came from
Alderney back to the needles, motoring into a nasty head wind the whole way
- Time taken 10hrs exactly - Distance just over 60 NM
Tim - Xiphion 1209
Tim Buckley
Shipshape Services Ltd.
Tel: 023 92 466 277
Fax: 023 92 466 249
Mobile: 07866 622466
www.shipshapeservices.co.uk
This e-mail and any attachment is intended for the named addressee(s)
only, or a person authorised to receive it on their behalf. The content
should be treated as confidential and the recipient may not disclose this
message or any attachment to anyone else without authorisation. Unauthorised
use, copying or disclosure may be unlawful. If this transmission is received
in error please notify the sender immediately and delete this message from
your e-mail system. Any view expressed by the sender of this message or any
attachment may be personal and may not represent the view held by the
Company.
Shipshape Services Limited (Company Number 4966209) with its registered
office at Sparkes Marina, Wittering Road, Hayling Island, Hampshire, PO11
9SR England
_____
From: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] On Behalf
Of WL
Sent: 15 August 2006 14:24
To: AlbinVega@yahoogroups.com
Subject: Re: [AlbinVega] Fuel Usage for Albin Vega equiped with diesel
Wilhelm, V-257
Nov 8, 2001
1,818
Hi Ray
12x8 is just too small and 12x9 is just too big! Perfect would be a
12x8.5
I have a 12x8 and works great.
Concupmtion is good when at sensuible revs, if you hammer it then
consumption will rocket!
Cheers
Oct 31, 2019
562
I have a Yanmar 1GM10 with 13/8 3 blade prop and 261:1
gear.
At 3000 rpm I run about 6.5 mph (5.7 kts) with about .8
liter fuel consumption.
Wilhelm, V-257
Oct 31, 2019
19
Are you talking the Bank Holiday Weekend?
Might be able to meet Fri night, but have commitments Sat afternoon so would
have to leave at lunch.
Will call you
Tim
PS - Word of advice for anyone fitting a new mast to a VEGA. Fill the hole
that the wires go through. I didn't and now have to lift the mast again as
every time it rains water pours down below - New mast has the halyards etc
running inside, not like the original.
Tim Buckley
Tel: 023 92 466 277
Fax: 023 92 466 249
Company.
9SR England
_____
Of Steve Birch
Sent: 16 August 2006 13:05
Subject: RE: [AlbinVega] Fuel Usage for Albin Vega equiped with diesel
Hi Tim
Will you be going to the Vega do? Starts Friday afternnon/night at
Haslar!
Nov 2, 2019
5
Albin Albin Vega 27 Rotterdam
I have MD7A on my Vega, I calculate 1lt/hour at abt 5 knots of speed. My RPM gauge is not working so cannot say anything about the power :)
Dec 14, 2013
49
Albin Marin Vega 27 Venice
In line with what written by Steve and Metacentre, my Vega, equipped with the Volvo MD7A and the original Volvo Combi system (2 blades feathering prop) on a flat sea without current, was consuming 1L/hour at 5 knots and 0.7L/hour at 4 knots. Now I have installed the Beta 14 but I have not yet tried it.
Marco Baldan
Albin Vega 3339 - Spray
