If the tank isn't leaking, I do not see a reason to replace. Most fuel gauges are useless even when working. If you have Yanmar 2GM the average burn rate for that engine is approximately 1/2 gallon per hour. If you have an hour meter jot down the reading after you top off the tank to full and every hour after that you have used 1/2 gallon. Check the size of the tank in gallons and take away 20% to account for unusable capacity and an emergency reserve. If your tank is 18 gallons, just assign 14 gallons as the usable capacity and that will give you 28 hours of motoring. By keeping tabs on the hour meter you will be able to safely estimate how much usable fuel you have left at any time. This is just a quick and dirty method. The burn rate method of calculating can be refined into a more exact number which could be used for trip planning and to calculate range between refuelings during a trip. look at the archives as there is plenty of info there on how to use it. I have not ran out of fuel since I started using the method and fuel gauge failed some years back and have never bothered to replace it.
