Fuel tank/sender
Growl
Oct 11, 2020
109
Hunter 28 2 Alamitos Bay Marina
Think I should just replace the tank with a shiny new aluminum one or bother with a new sender?
Fuel gauge hasn’t moved since purchase,
The hole has already been cut from the honey pot removal. Hardest thing to do would probably be moving the batteries around and or relocating them.
Mar 6, 2008
1,532
I replaced my fuel guage sender with one that has a floating doughnut ring.
dmax
Jul 29, 2018
1,362
Telstar 28 Buzzards Bay
Or you could get a plastic tank through which you can see the fuel level - never lies.
Catalina 320 Dana Point
I'd suggest figuring out if it's the gauge or the sender, last time I had a problem it was the gauge.
RoyS
Jun 3, 2012
1,742
Sender is easy to replace as long as there is enough space above the tank to install the new one. Be advised the circular mounting plate only fits one way. The screw holes are not equally spaced. Found that out the hard way.
Growl
Oct 11, 2020
109
That’s what I’m thinking a can of worms! I’m going to try adding fuel and see if at least the gauge registers full.
May 24, 2004
7,235
CC 30 South Florida
If the tank isn't leaking, I do not see a reason to replace. Most fuel gauges are useless even when working. If you have Yanmar 2GM the average burn rate for that engine is approximately 1/2 gallon per hour. If you have an hour meter jot down the reading after you top off the tank to full and every hour after that you have used 1/2 gallon. Check the size of the tank in gallons and take away 20% to account for unusable capacity and an emergency reserve. If your tank is 18 gallons, just assign 14 gallons as the usable capacity and that will give you 28 hours of motoring. By keeping tabs on the hour meter you will be able to safely estimate how much usable fuel you have left at any time. This is just a quick and dirty method. The burn rate method of calculating can be refined into a more exact number which could be used for trip planning and to calculate range between refuelings during a trip. look at the archives as there is plenty of info there on how to use it. I have not ran out of fuel since I started using the method and fuel gauge failed some years back and have never bothered to replace it.
RoyS
Jun 3, 2012
1,742
Looks like someone fastened the gauge with two self tapping screws and abandoned the original fasteners. In the photo it looks like there is some kind of fiberglass patch nearby. Possibly the gauge was moved from there, who knows? New aluminum tank will run about $450. Installation may be difficult if it is inaccessible or the supporting base needs replacing. Mine leaked after about forty years. If your tank is over thirty years old, I would replace it before it fails.
RoyS
Jun 3, 2012
1,742
Just noticed that you said it is a plastic tank. Disregard my comments concerning aluminum tanks above.
