1986 Pearson 28-2. Diesel, alum fuel tank under quarterberth.
While doing some engine work guys discovered I was getting water in the fuel-water separator (I know, that's what it's for) - water was evident immediately after draining the sump so determined there is water in the tank. I'm a new owner with zero maintenance records so it sounds reasonable to me.
In an attempt to drain the water, I ran 7' of plastic hose down the filler neck until I couldn't go any farther - resistance. In fact the hose never reached fuel and came back dry each time - pumping produced nothing.
So, my fuel gauge sits on top of the tank (float type). I reckon I can remove and stick my hose (clear plastic hose to be precise) into the tank and pump the water out.
Guess I'm really asking is there another way or has someone else done this and it works great, or you blew up your boat!
Thanks.
Jim
Thanks.
Jim
