Has anyone removed the fuel pick up tube and valve? I need to find if there is a screen on the tube, or if I have some type of blockage. Does it just unscrew from the tank?
My engine starves for fuel, then stops.
I have an electric pump in line, and when I turn it on the engine starts without bleeding air from the fuel filters.
I have changed both my Racor and the second filter on the engine, also changed the engine mounted lift pump.
My next attacks are the fuel vent, valve and tube, along with new fuel lines.
The boat is a 1984 Hunter 34.
