Fuel Level Gauge for a 31
57
Hunter 31 Port San Luis, CA
I just purchased a Hunter 31. It does not have a fuel gauge currently. Has anyone had the experience of installing a gauge on a 31? Would I need to remove the tank? Are there kits available for this? Or am I relegated to the "consumption per hour" method?
Dec 2, 1999
15,184
You would need to cut a hole in the tank for a fuel gauge. I don't know about sealing the fitting after the hole is cut either.
If you decide to do this check out WEMAUSA.COM. They have nice electric units at a very reasonable price.
May 24, 2004
7,235
CC 30 South Florida
The fuel gauge on the boat stopped working a couple of years ago and I have not missed it the least bit. The only information it reliable provided was wether the tank was full or empty but could not give a useful approximation of available fuel in between. I have always relied on the hour meter and the engine's average burn rate. This provides me quite closely the amount of fuel I have left on the tank at all times. I check my figures everytime I refuel and I am consistently inside the short end of a 1/4 of a gallon for a 10+ gallon refill. It is great when you can approximate your fuel availability to a 30 minute span. It takes practice but I can take a glance at the hour meter and know pretty closely how much fuel I have left. I could not do that with the fuel gauge. Sorry for the dissertation but cannot understand how someone can be relegated to a superior method.
Oct 14, 2005
2,191
Mellis...
I put a fuel gage sender in my H34's tank when I had it opened for a clean-out. Cutting in any hole will put debris in the tank so you need to consider the consequences. I tapped the mounting holes into the tank plastic and used the gasket that came with the Tempo gauge. Haven't had any leaks in the four years since.
Attached is a pic of the tank top. The gage sender is the small silver thing near the fill hose.
89
Hunter 31 Portage De Sioux, MO
Millis... you did not mention the year of your 31. I would like to know how your project comes out. I have a 87 Hunter 31 and the fuel tank is hard plastic. I have also thought of installing a fuel guage, but haven't decided on how to do this. The tank is square in shape and the top has a little age sag in it, which I think will cause a leak problem if a hole is cut in the top where you would put the sending unit.
Benny, I like the sound of your system. Not really interested in installing something that will cause me headaches down the line. If you guys knew how I read the fuel level now, I may be laughed off this web site............
Apr 5, 2010
6
Hunter 30T Corpus Christi
You can buy a sender that uses the same hole as the fuel return line and does both functions. I did this and it works fine.
