fuel fill hose
79
Hunter 29.5 Big Ridge Marina, Hixson, Tn
Please,
Advise on the diameter of the fuel fill hose for the 1995 Hunter 29.5.
Thanks, Dave
Dec 2, 1997
9,011
- - LIttle Rock
The standard size for all tank fill hoses is 1.5" ID
ID = Inner diameter. If you're in doubt, check the OD (Outer Diameter) of the hose barb on the deck fill fitting.
Btw, all hose sizes refer to the inner diameter. Hose barbs/fittings sizes are always the outer diameter.
Nov 23, 2008
79
Re: The standard size for all tank fill hoses is 1.5" ID
Peggy, Thanks for your reply and advise... as a new Hunter owner my learning curve is vertical. I plan to do as much of the work that I can and doctument the experience. Hopfully I can 'give back' one of these days.
Dave
