Fuel delivery issue
Jun 15, 2012
715
BAVARIA C57 Greenport, NY
Why not completely eliminate the existing fuel supply? Rig up a diesel fuel supply from a small 1 gallon can, a hose barb fitting and a length of hose. Hang the can above the engine, eliminate air in the hose and attach directly to the fuel injection pump. If the engine now starts, the problem is the fuel supply. If it does not, the problem is in the engine.
Fleet
Feb 8, 2021
27
Catalina 310 108 Lake Guntersville
Problem solved. Replaced just the lift pump. Engine started up and the alarm went off at key position 1. Will take her out tomorrow and run her. It sounds like the lift pump was bad since the day I purchased her. Thanks for everyones help
