I'm not sure I understand this statement. Measuring the non-occurance of something is much trickier than measuring the occurrence of something. In this instance measuring the occurrence of the compressor running is easier than measuring the non-occurrence. Measuring the occurrence is also the circumstance the OP wants to measure, how much is it running.It might be easier to measure the time it's not cooling, since this could involve just wiring the Hobbs meter across the thermostat; when it closes, i.e., calls for cooling, the meter stops.
Curious if what you said about the current is in theory or have you actually observed this? If you did actually observe this (a spike and then I assume nearly constant current the whole time the compressor is running) what type of fridge? Maybe some fridges do this but its not at all what my Isotherm with Isec does. My fridge may start up with something like a steady 5 or 6 amps and then ramp down to I believe even as low as 2 amps. Going from memory so could be off a little but the time frame for this might be 10 minutes or more depending on ambient. If I were to pick an "average" in say the first 20 seconds, I would way over estimate what the actual average is. Its certainly possibly that the Isec controller is why I see something so different and you dont have this.. but still wondering if you have actually watched the current say for 10 minutes or more? I suspect that the current to the compressor will vary depending on how hard the compressor is working and that will ramp down for each cycle.When the T-stat calls for cooling the compressor will start and draw a non-trivial amount of current, which I think is the current of interest. True, the initial surge to kick the compressor on will only last for fractions of a second and amounts to a trivial amount power used.
There are 2 measurements needed, average amp draw while the compressor is running and the time the compressor is running. If there is a decent digital ammeter in the system (and there should be) getting the current draw will be easy:
The current draw at any given time may be lower, however in a 24 hour period how much more efficient is your system? Does it simply draw less current for more hours? Or does it draw less current over all?My fridge is an Adler Barbour with a Danfoss compressor, but I have an upgraded, "smart" controller and a variable speed compressor, so it "learns" the 'burn time' and reduces compressor speed to run longer on/off cycles, which are apparently more efficient. So, current draw will vary.
I have the parts, and have been meaning to build my own "Power Duct," to suck cooler air into the condenser, which can make a big difference in efficiency.
And apparently by running longer cycles at lower compressor speeds. (So sayeth Danfoss, anyway.)Refrigeration can be made more efficient by reducing motor losses and improving condenser cooling.
The compressor is one part of the cooling equation. Another part is the evaporator/holding plate. Our refrigerator, a Grunnert, has 2 very large holding plates. These will chill down into the 20° range and keep the refrigerator cold, much as a block of ice. It can be run when the engine is running so it is not draining the battery as the alternator supplies the power, thus it has little drain on the batteries.And apparently by running longer cycles at lower compressor speeds. (So sayeth Danfoss, anyway.)
A battery monitor may be the only way to measure the consumption if the compressor has variable loading.I cannot find an analyzer that measures current either by series or clamp on methods. Then there would be the time issue of when the analyzer turns on/off especially with different amperage draws which would require settable trip points.
Nor will it give you accurate information. I had reason to test a similar product. It was around 20% fast.This gets cheaper all the time.
You can now measure you refrigerator's TIME ON during the day for only $3.41 CAN.
At that low price, better get several because the meter isn't going to last for very long!
This is might be the easiest way to go. What you proposed doing is possible, however the data set would be quite large and the calculations to get really good insight in to the factors involved would require some statistics that I have long since forgotten how to calculate.Thinking maybe a 120W panel that could get me 6a (Full daylight) and forget the refer analysis…I will get what I get for not much money.
Mark,Being the OP, some interesting discussion here. I have an AB refer that draws up to approx 7a. It is variable. Any device to measure this would have to be connected somewhere after the compressor or the fan or whatever. Otherwise the analyzer starts marking time when the breaker is on. I cannot find an analyzer that measures current either by series or clamp on methods. Then there would be the time issue of when the analyzer turns on/off especially with different amperage draws which would require settable trip points. I would already know the V…
There are two reasons I'm looking at this. One to determine if I should spend the effort for more insulation which would be on the inside and I really don’t want to that. Second is sizing a solar panel..I do not want a solar farm on the boat. I thought I would get a portable suitcase panel and open it up on deck (not underway) and run the wiring into a cigarette lighter which currently exists right to the battery bank. Thinking maybe a 120W panel that could get me 6a (Full daylight) and forget the refer analysis…I will get what I get for not much money.
For $30 you can get a cheap charge monitor and it will log how much power you use, but not cycle time.
BTW - thanks for the heads up on a cheap little box like this. I ordered one yesterday. I can see it being handy for an assortment of things about loads on an adhoc basis. In the past I have usually just spot checked with the 'clamps' around the wires, but this is so inexpensive that it made since to buy one and try it out.
Compared to what? Mine draws 5A. My previous one drew 5A. It might dip a bit below that when the compressor is run at lower speeds, but not enough to make a 5A estimate significantly less accurate.When the compressor is running is when the true miracle is evident by how little current they actually draw.
I agree. What has made a huge difference is the modern materials, amongst them being magnetic components that produce much higher flux densities with lower losses than was ever possible in previous generations of machines. These advances are showing up in cordless tools, electric bicycles and numerous other applications. Higher tech insulation also contributes.There was a time when 12 volt Refrigeration compressors where not not available.
just about any and all 12/24 volt Refrigeration systems are nothing less than a modern-day miracle.
