Fresh water strainer replacement...recommendations?
Oct 28, 2013
129
Hunter Legend 35 Fairfield, CT
Our bronze water strainer is original to our '87 Hunter 35, it is not in great shape, and I am looking to replace it. Does anyone know what unit is recommended for Yanmar 3GM30F? Thanks!
Gunni
Mar 16, 2010
5,937
Shop Groco. Made in the U.S. Just fit to the hose nipples. Strainers are not a specialty part.
Feb 2, 2006
470
Hunter Legend 35 Kingston
What's wrong with the original? Mine is a Perko, and I installed the gasket kit, cleaned up the plastic cylinder and it should be good for another 30 years. There's not too much to go wrong with them that the gasket kit wont fix.
Chris
Oct 28, 2013
129
The only reason for the replacement is that the current unit is just so corroded, green, and it bleeds into the engine bilge... just trying to figure out the GPH to make sure that I get the right one. Groco is my choice as well.
Ted
Jan 26, 2005
1,272
A new bronze strainer will look like your present strainer in a few seasons. I would recommend cleaning your existing bronze strainer with a home made concoction of white vinegar, flour and salt. Check out this link for the specifics. http://www.howtocleanstuff.net/how-to-clean-bronze/ I personally like to use more white vinegar and most of the time straight white vinegar does the trick.
JamesG161
Feb 14, 2014
7,817
Hunter 430 Waveland, MS
If you have at least 90% of flow area, why clean it? Corrosion "crust" is natures way of "scabbing". Cleaning will expose more fresh metal to just corrode again. If the flow is restricted, gently brush it open and rinse.
Jim...
Feb 2, 2006
470
Does "bleed" mean "leaking"?
Chris
Oct 30, 2011
542
klidescope 30t norfolk
Find part # for existing perco strainer you will find that's a $400 strainer and they sell a rebuilding kit with rubber or cork gaskets I chose rubber . Clean and enjoy the 300 + dollars left in your pocket
Dec 25, 2000
5,946
Our original 1991 sea water strainers (three on our boat) look green, but clean up nicely. Our 4JH2-TE uses this type, which should work for your engine:
https: //www.walmart.com/ip/34051369?wmlspartner=wmtlabs&adid=22222222222022559995&wmlspartner=wmtlabs&wl0=e&wl1=o&wl2=c&wl3=10363774937&wl4=kwd-1103087007705&wl12=34051369_10000002178&wl14=bronze%20sea%20water%20strainer&veh=sem
What do you mean by bleeds? Do they leak water or air? If water where do they leak? These strainers are almost indestructible, but do require periodic maintenance. If you do replace yours, would you please throw your old one my way? :poke:
129
Our current strainer does not seem to be leaking water. But it does leave a green mark on the walls and inside the bilge under the engine. I was thinking more of cosmetics and then function. I will certainly try the vinegar concoction. Thanks, and will send pics of the post vinegar treatment!
Dan_Y
Oct 13, 2008
519
Hunter 36 Hampton
I followed Mainsail's page for rebuilding a strainer. I had a perko with the cork gaskets. After getting the bronze all clean and shiny, i sprayed it with a thin coat of clear lacquer. looked like new from that point on...
