fresh water leak
P
pfrontera
it appears i have a water holding tank leak . when i fill tank ,it leaks a couple of gallons into bilge, any suggestions? thanks
Dec 2, 1997
9,011
- - LIttle Rock
WTG Terry...
If you're only losing a couple of gallons when the tank is full, the leak has to be at the top of the tank. If it's a FG tank with a lid, that's prob'ly the source and fairly easy to fix.
Oct 18, 2008
45
Jeanneau 49DS Seattle
Check the fittings on the bottom of the water tank to ensure they are not the culprit. If there is a leak there get them fixed right away. Check and replace the fittings not just add some silicone to the outside. A stich in time....
jtm
Jun 14, 2004
314
Hunter 28.5 Dataw Island, SC
dusting
get some talc and dust the area below the tank and perhaps up the sides- the leak will wash out the powder and you'll have a trail to the source.
