Bob
I am still trying to solve an overheating problem (see "Hot Engine" post of 8/26/01)The engine heats very quickly and very hot under load. This is a Universal 25.I am satisfied that the raw water system is functioning as it should. I have taken the thermostat out and tested it. It opens properly.I now suggest that the flow of the fresh water is blocked or inadequate. If I feel the fresh water input and output hoses on the heat exchanger there is a definate difference in temp. but when I remove the radiator cap and look for signs of flow, I am not able to see anything that looks convincingly like the water is flowing through the system. I see movement in the coolant but this is more like a jiggeling then a flow which is probably just from vibration. Does anyone know how to test the fresh water pump and/or confirm that the coolant is actually flowing adequately through the fresh water system.Any help would be appreciated.
