2000 Hunter 340….Today I found some antifreeze under my Yanmar 3GM30F. It cleaned up with some paper towel but I can’t find the source. This same thing happened last spring and was about the same amount. It never happens during the sailing and motoring season.
The only thing I do see is that the overflow container has lost some fluid. It is always just under the Full line, today its is about 1/4” above the Low Line.
I looked for drips, signs of antifreeze stains all under and around the motor but there are none. The antifreeze level under the radiator cap is full. Checked the petcocks (2) on the sides of the motor and all are dry.
I loosen the fan belts at the end of the sailing season to lessen the tension on the alternator and impeller pump but that has different antifreeze from what I found.
It‘s puzzling to me that it only happens during the winter. This winter was very cold compared to others.
Any thoughts as to a cause. Thank you for the help.
