Fouled Windex
254
Hunter MH 37 Manitowoc, WI
Don't ask me how it happened, but somehow my windex is fouled on my VHF whip antenna. I think it happened when we gybe'd last Tuesday. I know it was working when we turned into wind to set the sails. I think I'm going to have to go up there. Anyone ever have this happen?
Oct 29, 2005
2,366
Nope. I suppose your vhf antenna is mounted on an L-type bracket that is short? Mine put the antenna at least 6" away from the mast and my Windex is at centre of mast, atop the Anchor/steaming light combo. I've no clashing issue with these two.
Jun 6, 2006
6,990
The wip antenna probably bent over at just the wrong time as the windex turned past it. If you are going up the mast you might as well inspect the anchor light while you are there. don't forget your hand mirror.
snows
Aug 22, 2011
30
Hunter 410 Charleston, SC
When my wife and I were motoring offshore in 5' seas, the tip of the mast on our Hunter Vision 32 was whipping so wildly that the antenna flung itself under the anemometer. This weekend I successfully unhooked it using a piece of copper wire attached to the main halyard. It took about an hour, so going up the mast may have been a quicker way.
