Forward Window leaks on the H41DS
Nodak7
Sep 28, 2008
1,256
Hunter 41DS Punta Gorda, FL
We have a 2006 H41DS and the forward window (Port & Starboard) have begun to leak. I tightened the Philips head screws on the inner ring and that stopped the starboard one from leaking but the port leak persists. Has anyone with a DS had this problem and been able to resolve it? Looking for suggestions for resolution please.
Rick
Oct 5, 2004
1,098
Hunter 420 Passage San Diego
They probably need to be re-bedded, meaning taken out, cleaned and re-sealed. This is a tedious job but not that hard if you are handy. Otherwise a local shipwright could take care of it. 16 years.... thats pretty good durability.
Cheers
Looking at an image of a 2006 41DS forward window it has similarities to my windows.
Mine have laminated glass attached to the aluminum frame. The frame is set in a hole and sealed to the boat by either butyl tape or 4000UV adhesive caulk.
I took my window frames to an auto glass shop to replace the glass and properly reseal the glass in the frames. I have the windows back at the boat, and I now have to prep the boat decks to reinstall the windows.
