Forestay
128
So I've decided to abandon the roller furler and go to hanked on sails.
So get this, I ordered the sta-lock fittings, wire, turnbuckles and a
new (used) working jib, plus wire cutters for less than the riggers I
talked to wanted for coming up to Baltimore and replacing the stay in
the roller furler!
Tom
Oct 30, 2019
1,459
For cutting wire (including 1 by 19 SS), a Dremel tool with cut off wheel works really well, and you get a very useful tool for less money than a big wire cutters. I used the Dremel on my recent lifeline replacement and it worked great.Nicholas Walsh
Nicholas H. Walsh P.A.
111 Commercial Street
Portland Maine 04101
Tel. 207/772-2191
fax 207/774-3940
This email was sent from the law firm of Nicholas H. Walsh P.A. It may contain information that is privileged and confidential. If you suspect that you were not intended to receive this email, please delete it and notify us as soon as possible. Thank you.
Sent: Tuesday, June 24, 2008 9:44 AM
To: AlbinVega@yahoogroups.com
Subject: [AlbinVega] ForestaySo I've decided to abandon the roller furler and go to hanked on sails.
the roller furler!
Tom
Oct 2, 2005
465
I want to replace the double forestay that I inherited with a single forestay, and I have the mast off the boat. But now I have doubts about the accuracy of the measurement I took when the mast was in place. Does anyone know the length of the forestay? ( I can't use the measurement of one of the doubles because they are shorter) Thanks.
Craig Tern 1519
128
Hi Craig,
I replaced the forestay on my series 1 last year and the measurment was 31' 9 1/4" This is pin to pin and I ran the forestay from the stem up to the aft hole on the crane. I used 1/4 1x19 wire with sta lok fittings.
If you go with swageless fittings, like sta lok, you can fasten the top to the mast and then support the mast with a halyard and cut the forestay to the length required by your turnbuckles etc. I replaced mine with the mast down, but then I could measure off of the old stay.
Hope this helps,
Tom
