Terminal Fittings-Advice Requested
OK, now I'm planning my repair/replacement. After I shorten my furler, I plan on adding a toggle on the upper end of the forestay between the T-Ball terminal fitting and above the point where the forestay enters the furler. The easiest way would be to find a T-Ball fitting with an eye bottom (similar to a T-Ball running back fitting) and connect the eye to the toggle, but I can't find such a fitting. Would a T-Ball running back work? My second option is to go with a T-Ball swaged fitting onto a very short length of wire rope and connect to a swageless toggle and then connect to a swageless eye. The first option would be simpler and less expensive (one less swageless fitting). I would very much appreciate your advice and opinions. Any other options? Thanks, BrianW
