Force 10 Oven Problem - Oven control knob won’t turn
Sep 27, 2008
252
Hunter 41 Longport,NJ
Older force 10 2 burner oven in 2004 Hunter 41. Both burners work fine, and the spark in the oven is there, but I can’t get it to light. The control knob pushes in to create the spark, but will not turn at all. Suggestions or thoughts ?
I have a 3 burner F10. It can be taken apart and rebuilt. I was having a problem lighting the burners. Removed each burner. Cleaned them. They light up without issues.
You can remove the controller. Inspect replace it if needed.
Nov 6, 2006
10,257
As jssalem says, the valve/igniter can be serviced somewhat. Most of those here in the USA are made by Robertshaw; Force 10 just buys the part from a manufacturer who's done the certification. Most of the time, the igniter is a separate part from the thermostatic valve. Get a number off the part and search .. if ya don't want to DIY it , you can remove the whole stove and take it to a shop that services gas appliances; sometimes an RV/motorhome shop can point you to such a shop. Good luck.
Sep 24, 2018
4,821
Catalina 30 MKIII Chicago
I had a similar issue with a Buddy Heater. I took the valve apart, found that the part that turns had sort of seized to the body. Some lube and light tapping freed it. I cleaned an re-assembled. Worked well after that
Sep 27, 2008
252
Thanks for all the advise. Was able to deal with it easily by just spraying some lithium grease into the valve - just removed the knob and shot it in, then wiggled it gently back and forth with a set of pliers on it until it rotated freely - thanks all
