Did a trouble shooting consult yesterday and found this. Note how the wire had been connected to the batt switch post by simply wrapping it and tightening the nut down.
There was soooo much wrong with the PO's DIY wiring on this boat it would have been difficult to know where to begin. I really felt bad for the guy but referred him to a good marine electrician as I do not have the time to tackle his job and my own lightning strike right now.
As a point of reference the MANUAL mode / side of a bilge pump switch should ALWAYS be a momentary type switch not an ON or OFF. You should have to hold it to keep it in manual mode not be able to turn it on and walk away. Catalina made a dumb mistake on this switch and the whole panel on this boat for that matter with multiple circuits sharing a single breaker.
The guys daughter accidentally turned the bilge pump switch to MANUAL as opposed to AUTOMATIC and the pump literally melted down and created a dead short. I wish I had my camera with me!
The dead short melted the approx 16GA wire between the battery switch post and the panel switch mounted bilge pump switch. It melted into the jacket of multiple other wires including a ground wire before the plastic bilge pump switch melted and broke the circuit. Switches should NOT be depended upon for circuit protection.
I gave the guy an in-line fuse holder that I had on-board at N/C..
FUSE your stuff !!!!!!!!!!!!!!!
This guy came about a gnat hair away from a really bad boat fire!!
Off to go sailing!!!!!!
