I may have babied the engine a bit by not running it up in that 80% range as I'm learning now I should have. I'll have to look up the procedure to do a Rydlyme flush.Have not had the problem but if you habitually ran the engine at a reduced RPM you may have some build up. A Rydlyme flush would clean it out.
Thanks
