Fixed port leaks, 2008 41s Hunter
dakno
Jun 22, 2009
209
Hunter 41DS new orleans
Both port and starboard fixed side port lights, rear positions leak from the bottom rear corner. Has anyone made this repair?
Sep 20, 2006
2,953
Yes, did one of mine last year. Make sure its clean of old caulking, and then scrub with soapy water then rinse with water. Mask off the topsides around the window & on the window, both inside and out for easier clean-up, and use the Dow silicone, although I used the Tremco version, of the silicone.
You can also search on the forums to find many other discussions on this.
