Yes, both fresh and salt water
Michael, If you are in salt water, try what they call a dolphin buster. It comes in many colors, blue, green, red, etc. and it has a sparkely metal flake imbedded in the lure. They look like they are a head with a hulla skirt and extremely jelly like. Let out enough line so that the lure is breaking the surface of he water about 20% of the time (the more line you let out the less it will break the surface of the water). Set the drag on your reel so that it will scream at you if something strikes it. This does two things, it alarms you that something is going on and also it won't rip the gills out of the fish if you are at hull speed. Be prepared to heave-to when you get one on. Spanish Mackeral, bonita, and barracuda are regular catches when we sail in salt water. In fresh water I troll a bomber about 2 1/2" long only when the boat is make less than 2 knots. I have had two interesting catchs doing this. The first was a 10" crappie that the mouth of the fish was the same size as the treble hook and half the size of the lure. The second was about a 12" perch.
