Fish finder glued inside the hull
Jun 2, 2014
602
Catalina 30 mkII - 1987 Alamitos Bay Marina, LB, CA
Not a really important topic, but I was messing around with a fish finder transducer in my Cat30, and wanted to glue it inside the hull.
I used one tube of clear silicone then another tube I thought was clear but ended up being white because I wasn’t paying attention.
And I wasnt thinking when I squeezed it out and didn’t think about air bubbles, so being a little too late to undo what I just did, I decided to see how well it would or wouldn’t work. Worst case I’d let it dry and start over later. I pressed the transducer into the blob and tried to squish it enough to try to flatten out any bubbles under it, and the immediate results were really noisy.
I waited a day for it to mostly dry and checked again, prepared to rip it out, but it looks pretty decent today. A bit of noise, but looks good enough to use.
Here’s the install, and the before and after pics of the silicone wet and mostly dry:
F482FE8C-5458-4386-B791-E413B616C805.jpeg 9446C36B-D50D-4824-A425-6CDC03245385.jpeg 9CB50396-7A78-46F0-8F72-31B4BCCEFE80.jpeg
Likes: Jim26m
Oct 10, 2011
619
Tartan 34C Toms River, New Jersey
Thru hull transducers work fine. I think you got a little carried away with the silicone.
End result is it worked.
Likes: jonelli
Jun 10, 2017
174
Catalina 1980 Catalina 30 Mk II John's Pass / Tampa Bay
J,
I also have an in-hull transducer in my 1980 C30. I picked a spot on the STBD near where the fuel tank is located.
If unhappy with the noise, here's how I found the right spot.
I placed my transducer inside a Ziploc baggie filled with water. I then moved it around while checking the unit for good signal strength minus any noise & marked the spot. It's also possible that the bubbles causing this may in fact be in the fiberglass hull & knot a problem with the caulking..
Just a thought pal.
Aug 3, 2012
2,542
Those top lines actually look like a picture of the bottom side of your hull. Kinda neat.
Likes: jonelli
Oct 24, 2010
2,405
Hunter 30 Everett, WA
I've used wax from a 99 cent toilet ring to stick it down temporarily (for a couple of years and also to locate where it will work well) and it works great. For a more permanent fix a glob of 3M 4200 has worked for me.
Ken
Mar 30, 2013
700
Ken
I "temporarily" mounted the transducer for my GPS/fishfinder in a glob of toilet ring wax 5+ years ago. Still works like a champ.
Likes: Kermit
Jul 23, 2009
917
I think I used Shoe Goo. It worked for several years, until I sold that boat.
Mar 1, 2012
2,182
ever try to paint or varnish on surfaces that have had silicone? Worse than trying to use 5200 (an adhesive) as a caulk..
