Fischer Panda Generators
182
Hunter 45cc Florida
I would like to get feed back from owners of Fischer Panda generators, as to any problems they are or have experienced. I have had numerous problems relating to the controller board and oil pressure switch, overcharging the battery, and exh gas temp sensors. I would like to find out whether my generator is an isolated incident or others out there have experienced similiar problems. Specifically, my model is the 8kwEtec
Feb 27, 2004
134
Hunter 410 N. Weymouth, MA
FP
the article Don referred to is one of their DC models. I've had a FP mini 8kw A/C genset since 2000 on my H410. absolutely no problems. not familiar with their 8kw Etec. Bryce
Apr 1, 2004
31
Catalina 470 Marina del Rey
We have a FP 8KW on our 2004 470. It has 275 hours
and we hve yet to have a problem. For my own education what is Etec??
Jan 4, 2006
283
West Coast
And So On…
It appears to be an attempt at "et cetera," the Latin phrase meaning "and the rest." The most common abbreviation of the phrase is "etc.", though it is still seen occasionally in its older form, "& cetera".
slipin away
Etec
Etec is Panda term for the generator with the high tech control panel, with multi function screen
F
Fischer Panda USA
Fischer Panda USA
Slipin Away, I would recommend that you give my office a call and speak to someone in our service department. They can be reached at 800-508-6494. If you are unable to get a hold of someone in service give me a call and I will have one of my technicians speak to you and see if we can solve your problem. As for the term Etec it refers to the self diagnostic panel that comes with the newer Fischer Panda models. This feature has been available for the past few years. The Etec or digital panel as we refer to it gives you all your load readings, temperature readings, hours and if you have a failure it will come up on the screen and tell you what is wrong. There are also several other features that come with this panel but I hope that gives you an idea. Feel free to call my office or email me anytime if you need help. I can be reached at 800-508-6494 or jtill@fischerpanda.com. I look forward to hearing from you, Jeff Till Fischer Panda Generators
