We swapped the 10g unit for a 25g Todd Tank. Ronco might have been a better choice. HUGE difference in autonomy
Also in wall thickness. Ronco's smallest tanks are about 3/8" and get thicker with size starting at around 40 gallons...corners are about 50% thicker. I haven't tried it, but I strongly suspect their tanks would only bounce if dropped off a two story building onto cement
I was actually wondering if I could get a tank that was mostly rectangular but had a few inches of step down at one end where the hoses could go.
Drawings for all non-rectangular tanks are in their catalog. Keep in mind that any tank can be oriented in any directions...'cuz there is no top or bottom till the fittings go in, and you'll decide where they go. So rotate, flip end for end for end, check every which way.
When you measure, be sure to allow for top fittings and hoses. The area is wide but not overly tall, and the fittings will shave inches off of available room.
Ronco's standard fittings put the threaded nipple outside the tank...if you want them flush, remember to specify that.
You'll need at least 5" clearance above the top of the tank to put the inlet and discharge fittings on the top. Vent fitting needs about 3 inches clearance.
It might be worthwhile to build a cardboard mockup of the tank to make sure you can get it below and it will fit., They will also let you define the tank fitting locations.
Good suggestion. 'Twould also be smart to make sure the tank will fit through the companionway hatch. I once had a customer who built his mockup while IN the boat...perfect fit for his v-berth location. But when it arrived, he couldn't get into the boat.
When you're ready to order, we should prob'ly discuss the best locations for the fittings...prob'ly NOT where they are on the existing tanks 'cuz boat builders, even the best ones, are the worst sanitation plumbers on the planet! My book (see link in my signature) also covers this in detail.
Peggie
"If you can't explain it to a six year old, you don't completely understand it yourself." --Albert Einstein
