C
Clyde
This topic has been around for a long time
I agree with Fred, a shotgun is better than a rifle or handgun on a moving boat at sea. As Debra B. has stated whenever you enter another country's territorial waters you must declare your firearms or face prison time. You are not allowed to have access to your firearms as long as you are in their territorial waters, they confiscate your firearms and hold them until you are ready to leave their territorial waters. When you are anchored away from civilization in a foreign country you are unarmed, the only time you have access to your firearm is on the open seas and in US territorial waters. Most sailors who carry firearms, carry shotguns. A rifle is a long range weapon and a shotgun is a last resort weapon use to defend against being boarded. At sea on a rolling sailboat, it's impossible to aim at targets that are also moving, why get a rifle that can shoot 300 yards when you only hit sometime less than 100 yards. Shotgun shells will corrode less by the marine environment than rifle or handgun shells. If you're sailing within the territorial waters of the US, then a shotgun is the best protection against unwanted intruders boarding your sailboat. Winchester has a 12 gauge stainless steel shotgun Model 1300 Coastal Marine, it's marketed for Alaskan coastal wilderness areas where a sailor can run into four legged intruders wanting to board your sailboat, you can use it against two legged intruders also. Mossberg also has a shotgun designed for the Marine environment, the Mossberg Model 500 pump action Mariner. You can also get specialty shotgun ammo that will shoot flares and other incendiary devices.Check the links on some interesting articles; "Guns On-Board", some tips on carrying firearms aboard ship and "Pirates - Beware", a modern day pirate story off the Florida Keys.Fair Winds,ClydeWinchester 300 Coastal Marinehttp://www.winchester-guns.com/prodinfo/catalog/detail.asp?cat_id=512&type_id=908&cat=012CMossberg Model 500 Pump Action Marinerhttp://www.mossberg.com/pcatalog/Specpurp.htmGuns On-Boardhttp://dockwalk.com/issues/2001/february/guns1.shtmlPirates -Bewarehttp://www.onshoremagazine.com/oscx/edit/052203_editorial.htm
