Finished bulkhead replacement project
John
Jun 3, 2006
803
Catalina 36mkII Alameda CA
Friends,
I have been bugging you with lots of questions regarding my project of replacing the bulkhead on my C36 MK II. If you go here: http://www.c36ia.com/node/1327, you will find a full report on this project plus a few photos, including some of the finished project. As always, thanks a lot for all the help and suggestions.
That is one SUPERB job, John. Well done and well documented. Thanks, I know a lot of C36 owners are gonna appreciate your work and guidance.
Nov 8, 2007
1,618
Thanks for the great description and pix
This is a possible repair for many of us.
Feb 6, 1998
11,772
Nice
Nice job John! It's good to see it all worked out and the match of the veneers looks very good!!
John
Jun 3, 2006
803
different colors
The new bulkhead is quite a bit darker than the rest of the wood, but I doubt there was anything I could have done about that.
I should note: When we first got the boat I was a bit intimidated by this job, despite my years as a carpenter. I felt it would be totally different. I got estimates ranging from $5-10,000 and up for it so I kind of put off doing anything about it and now I'm glad I did. Basically, I think almost anybody could do this job, as long as they have the tools and take their time.
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Epoxy Water Proofing
Very smart move sealing the plywood with epoxy. Make sure you seal the chainplate screw holes also as any future leaks could cause the new bulkhead to rot from water leaking into the holes. If you seal the holes this should last forever.
Excellent work.
Tim R.
May 27, 2004
3,626
Looks good John and a nice write up.
John
Jun 3, 2006
803
chain plate
Excellent work.
I resealed the chain plate screw holes and the penetration itself with butyl tape, as recommended by (I think) Maine Sail. If you notice, I also sealed the through bolts at the bottom of the bulkhead with butyl tape on the head side of the bulkhead.
A future job for me will be to reseal all the deck penetrations, including all the stanchions.
Nov 23, 2004
281
Columbia 8.7 Super wide body Deltaville(Richmond)VA
I have done this same repair on my Columbia 8.7. I had to remove the entire port side interior to get to the bulkhead to remove it. You were lucky that you were able to do it the way you did.
544
Bristol 43.3 Perth Amboy
Beautiful Job!
Beautiful work! Necessity is the mother of invention. Each job had its unique challenges. Having done the same job on my Mirage, I realize that you are left with a much better understanding of your boat!
