faucet handle broken
4
hunter 33 point roberts
Hello fellow hunter owners,
I have a quick question. I have a 2009 hunter 33. Last week end, my admiral attempted to use the hot water by turning the handle on my sink faucet.
the handle started spinning around and not grabbing the little teeths to actually turn the water on.
Looks like I now need a new handle as tighting up the screw does not work.
the under part in the handle itself is stripped.
Is it a common problem or is my admiral too strong!!!!!
Where would be the best place to get a handle only as I do not wish to change the entire sink.
Thx in advance
Jun 7, 2007
515
Hunter 320 Williamsburg
Easy fix
Find the nearest RV store. They'll fix you up quickly, and for a lot less money than a boat store.
Dec 2, 1999
15,184
If you figure out the mfg. you can probably get one for free from them.
Contact Hunter Marine for the mfg's name.
Dec 2, 1997
9,011
- - LIttle Rock
Boat builders use same faucets & sinks used on land
The only differences are, for instance, an adapter on the faucet to attach a handheld shower. You can find replacements, parts and repair kits--and even the shower adapter thingee--for most of 'em at most big box hardware stores.
Mar 18, 2007
86
Hunter 28.5 cedar creek lake, tx
fawcwtt handle
The same thing happened to my Hunter 28.5
I was able to get a replacement at Walmart. It was exact to the one on the boat. The adapter fit inside the plastic knob.
