These boats have a small main, the driver is the large jib. I've added a larger main sail which causes steering problems. If the main extends too far back it seems to control the direct of the boat.
Yep, and that would support the idea that this is not a sail designed for this boat.Good catch. Shouldn't the main sail kinda fit on the whole boom? This one (admittedly inside the sail cover) looks like it only extends 2/3 of the way back? In the words of the famous Wendy's grandma lady, "where's the beef?"
1. That main is way too small. Probably came off another boat.These boats have a small main, the driver is the large jib. I've added a larger main sail which causes steering problems. If the main extends too far back it seems to control the direct of the boat.
In the continuation of the famous quotes; Sherman Potter: "Horse hockey". I rather doubt that there's too many people here who would buy the premise that Hunter put an extra three feet of needless boom for fun. Nobody spends that kind of money in a production cycle when you're paying for extrusion by the foot.These boats have a small main, the driver is the large jib.
Those were the high aspect ratio sail plans, popular back in the 70's and early 80's. In addition to sail size, the rig tuning and sail trim can affect steerage. Also an old blown out mainsail will cause the boat to heel excessively and may develop weather helm causing the boat to round up, or turn into the wind.These boats have a small main, the driver is the large jib. I've added a larger main sail which causes steering problems. If the main extends too far back it seems to control the direct of the boat.
I'd offer that most of the commentary here about topping lifts is based around a sail that fits. In that case, a topping lift will interfere with the sail 9 times out of 10. In this case there is no reason at all to think that the topping lift, if tied to the end of the boom will be anywhere even close to the sail based on the picture.Your least expensive option is probably rigging an adjustable topping lift.
It would have to be a "rigid boom vang".Boom vang
Yes. You would not be able to balance the helm. You would get a lot of Weather Helm. Or Lee Helm in the case of not enough main.These boats have a small main, the driver is the large jib. I've added a larger main sail which causes steering problems. If the main extends too far back it seems to control the direct of the boat.
