Exterior trim wood species?
Sep 27, 2008
175
Hunter 33 Danversport, MA
Boat is 1982 Hunter 33
I have some wood replacing to do this season and want to make some attempt to match up anything I replace with what is already there.
I do not think it's teak. So if anyone has already done this research, it would be most helpful.
The hand rails are good as is but the companionway trim and the slide hatch trim are a goner.
Oct 6, 2007
1,165
Hunter H30 1982 Chicago IL
All the exterior wood trim on my ‘82 H30 is original and I‘m certain it’s teak. Since your boat would have been in the same factory the same year, it seems likely your trim was also originally teak. There‘s no telling though what kind of modifications may have been done over the last 44 years.
Likes: Timm R Oday25
Aug 10, 2010
116
Hunter 36, Quarter Berth Model Placid Harbor, Cuckold Crk, Patuxent River
Teak on our H36 in the places you mention. I replaced the cockpit combing pads where the main winches are mounted with synthetic "wood" - looks good, zero maintenance, but it is warped due to me adding the "kerfs" in it and it can't adhere to the gelcoat...also is a bit slippery. Not sure I'd recommend this route unless you can't find a suitable, natural replacement...
