Sterling Power 50A battery charger. I'm using the temperature sensor, but the cable isn't long enough to reach. So I added a phone coupler and extension cable. Problem is that the coupler doesn't always make a good connection, and the charger thinks the battery is quite cold, and outputs a voltage that's too high. This causes the Balmer Smart Gauge to display an E03 error almost all the time.
Anybody know if Sterling or ProMariner make a sensor with a longer cable, or if I can splice/solder the cable, or replace it with a generic sensor?
Thanks, Rob
Thanks, Rob
