I have a 1966 Bristol 32 footer with the original 4 cylinder engine. Started it up this spring and the wet exhaust is leaking water. This is basically a pipe that goes from the exhuast manifold to the back of the boat.
My plan was to pull the exhaust pipe and have the leak welded. But I started working on it today, and I am not sure that I can actually pull the exhaust out of there without pulling the engine. Has anyone else tried this? I can unbolt the exhaust pipe from the exhaust manifold, pull the gas tank ( it is on top of the exhuast pipe) but will this give me enough cleaarnce to pull the pipe out of there? Would it be easier to try to patch it?
Any advice would be greatly appreciated.
Jerry
Jerry
