Exhaust Extension
704
Catalina 30 Sidney B.C.
I was wondering if anyone has added an extension to the engine exhaust on the stern to keep the transom cleaner from swirling exhaust
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
How dirty does your transom get. If it is bad, it could be a sign of an improperly pitched prop.
Dec 2, 1999
15,184
I would ask you the same question as Higgs. If you transom is getting that dirty I would wonder if my engine is operating properly. Having too much prop is a common cause. There could also be some other engine issues, but this is a good thing to have checked.
Have a similar prop sized for your boat and compare the specs to your current prop.
Jul 8, 2011
704
Not that it gets real dirty and I have had all checked out and yard mechanic says it is fairky normal as I have to run engine pretty hard against tide . I say one on a boat that whent buy and looke real practical , it was only about 6 inches long
Nov 6, 2006
10,253
Reminds me.. While sailing by Thomas Point Light off Annapolis one fine day, we encountered a very nice looking older boat motoring along toward us. As he passed, we saw he had rigged a "tail" of what looked like clothes dryer vent hose to keep the smoke off his pristine transom.. The tail was about 8 feet(!) long and wagged and pooped along behind.. The effect was comical and really unfortunate !! Ya don't want to do that ! Wish I'd have taken a picture..
Nov 2, 2010
114
Precision 28 Ashland, Oregon
The PO used a two inch piece of pvc pipe with a 30º bend, downward. He seems to have attached it with caulk, or something similar (it wiggles a little when touched). His motivation was to keep from squirting water in his dinghy, and instead direct it back to the sea (or actually the lake). It seems to work well...
Jun 7, 2004
99
Catalina 309 Ottawa
We have a number of Catalina owners at our club that have used a small extension to their boats exhaust. They've taken a small medical sample bottle that is handed out by your doctor, removed the top and cut out the bottom with a knife. This open cylinder friction fits into the exhaust vent on a Catalina and offers a 3" extension to the exhaust which is just enough to stop the exhaust from fouling the stern. It can be easily replaced if lost during the season, but surprisingly they last for years.
tcbro
Jun 3, 2004
375
Hunter 33.5 Middle River, MD
What about generators? I was thinking that people with generators could put extensions on the exhaust and discharge under water. This might keep the noise down when they run their gensets all night at anchor.
Do you think that will work?
Tom
Beneteau 323 Annapolis MD
Tom
I think someone tried that and decided it was too much back pressure for such a small engine?
Nov 26, 2008
1,970
Endeavour 42 Cruisin
I'm experimenting with an extension for my honda 2000. Tapped the exhaust port and screwed in a short brass nipple, added on a bushing and then a piece of flexable 1" aluminum conduit. Carries the exhaust away from the boat and muffles the sound a bit. Gets HOT. I did not run this under the water, just out the back of the transom over the pushpit.
May 4, 2005
4,062
pics!!! ???
I need to do something about the heat on my h2000.
