I am having trouble getting the unit to track well under sail and the autopilot is erratic. If you have had success could you provide the values for the following
Tack angle degree
Hard over time
Pilot response
Rudder Damping
Rudder limit degrees
Will the limit prevent the rudder from hitting the stop? My unit set at 30 seems to blow on by and I have to intervene to keep it from hitting the stop.
Thanks
Tack angle degree
Hard over time
Pilot response
Rudder Damping
Thanks
