So the " Must Read" link you provided basically says don't wast your money on additives, most actually contain alcohol and make matters worse.
Exactly. Practical Sailor also ran some tests that reached that conclusion. Great marketing though.So the " Must Read" link you provided basically says don't wast your money on additives, most actually contain alcohol and make matters worse.
Our marina in Punta Gorda Fl carries ValvTech gas and diesel that is Ethanol free.Also found a source for ethanol free gas.quote]
Where do you find this??
Try directory:
http://www.valvtect.com/marina_search.asp
So let me get this strait, by putting water in the gas it precipitates the alcohol out. Do you shake the tank up real good to make sure it is mixed, well it's not really going to mix, so I'm not sure how effective it will be, the water will go strait to the bottom of the tank.You can pull the alcohol out by putting some water in the can of gasoline, then after letting it sit overnight draw the water/alcohol from the bottom and using the alcohol free gas. I have a fuel pump with the pickup tube wired to a dowel so I can pump the water into another container.
Its 105+ octain with ethanolIf you know a drag racer or have a track in your area you can probably buy enough race fuel from them for a season. It's spendy but 105+ octain and you'll be able to plain all the way home. The cost used to be around $6 a gallon.
Ray
Really ? I've owned and operated airplanes and read aviation magazines for decades and never run across any information about 100LL avgas "burning hot". Higher octane means the gas air mix can be compressed more without exploding. 100LL contains tetraethyl lead to boost the octane rating. It doesn't change the energy content of the gasoline. Can you supply a published source to confirm your information or an explanation for the allegation that it damages engines ?I just found out that AV gas burns real hot and will wipe out valves and I'm sure other stuff.....
Back in May when this post started I called a friend who's a pilot and is pretty knowledgeable about all kinds of engines so when he told me it seemed to make sense and I didn't what to find out the hard way and after reading Rick's post it makes even more sense .Really ? I've owned and operated airplanes and read aviation magazines for decades and never run across any information about 100LL avgas "burning hot". Higher octane means the gas air mix can be compressed more without exploding. 100LL contains tetraethyl lead to boost the octane rating. It doesn't change the energy content of the gasoline. Can you supply a published source to confirm your information or an explanation for the allegation that it damages engines ?
