to the head mistress
the boat had a recycling sanitation system. i converted it to a regular configuration of head to tank. tank thru hand pump to sea. the holding tank is only 8 gallons. what i want to do is install a y valve so i can go directly to sea when off shore.
the problem is that the whole system is only 4 feet long and all the hoses and pump are under the sink in the head and room is very limited.
i can fit a y valve in the hose from the head to the tank. question is if i put a tee between the hand pump and the thru hull will it back up into the pump? the pump is about 1 foot higher then the head and the thru hull.
the other thing i wanted to ask is enzyme in the holding tank. will they live in a salt water enviornment or is it a waste of time?
thanks in advance for all the advice
greg
dalliance e35mkII
greg
dalliance e35mkII
