I started removing the trim edge from a rotten bulkhead today. Sadly (and contrary to what I've read) the trim broke into quite a few pieces, despite my best efforts to keep it as whole as possible.
Fortunately, I was able to glue the pieces back together relatively well, and I think with a little sanding and refinishing it will be hard to see the damage. Question is, how to reattach the trim to the new bulkhead, when the time comes? It was stapled and glued from the factory, but I don't want to risk using any staples/brads/etc for fear of damaging it again.
What I'm considering is, using thickened epoxy resin as an adhesive. Lay a bead of it in the hollow of the trim, then "clamp" the trim pieces to the bulkhead with bungees while they cure.
Anybody see a problem with this?
Trim reconstruction in progress ...
