Engine whistle or squeek
69
2003 Hunter 326 Lake Erie Ford Yacht Club
I have a Yanmar 2GM20f in my 2003 326. When I am at low rpm their is a slight whistle or squeek coming from engine. It sounds like it is right below my feet by the shaft area. Even though the engine is 7 years old, it only has 100 hours. Could this be the stuffing box. Any idea areas I can check. When I accelerate the sound goes away.
Hunter 2009 31 Northpoint Marina IL
We have a 2009 31. The belts made a similar sound. Simple adjustment. We still had our boat yard take a peek just in case it was something more.
Dec 2, 2003
1,637
40 years ago my old Ford car developed just such a squeak. I ran it into the garage and the mechanic and I stood looking and listening to it with the hood up.
Then he said "Look away for a moment" I did and when I looked back the squeak was gone.
Eventually he let me into the secret. The fan belt was squeaking on the dynamo pulley. Not a slack belt but just rubbing on the cheeks of the pulley. What he had done was to whip the dipstick out and just touch it on the belt. A tiny drip of engine oil on the side of the belt stopped it squeaking.
Lesson learned - thanks pal. No charge.
Maybe your problem also?
Sep 1, 2009
69
Thank you. I will try those 2 suggestions. The stuffing box appears to be dripping at the proper rate and the belts are pretty tight. Sound only happens when I am in forward gear.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
I had this same type of squeek in my 2GM20F prior to replacing the cutless bearing. After replacement, squeek gone...
Oct 29, 2005
2,366
ooh.. all I got for my cutlass is cloaking like lots of loose marbles until I change it out, the cutlass not marbles.
jtm
Jun 14, 2004
314
Hunter 28.5 Dataw Island, SC
Have you recently adjusted your packing or replaced the packing??? While it could just be a harmonic type whistle of some sweet spot, I also know that if you had repacked (like with gortex packing) and you hear a whistle more like a whirring - its could be your packing hasn't "set" or saturated yet. I'd watch it for leaking after running under load for a while and also feel for heat. But the packing does take a while to "set" and may need further adjustment. keep an eye/hand (latter when not stopped -not running) on it
jtm
Jun 14, 2004
314
fix typo - after the shaft it stopped !!!! you can feel it -- not when running ! sorry 'bout that
