Has anyone ever had to replace their engine stringers ? I just tore out all the wood in the bilge, removed the engine and decided to replace the motor mounts. Low and behold the starboard engine stringer is a bit wet and punky. I've cut the glass off, drilled holes dried it with heat lamps and am thinking of trying the west system with 404 and then reglass over. The smarter side of me says just replace them.
Thoughts ?
Thoughts ?
