I am struggling with a perplexing mystery. A customer's Catalina 27 with an Universal diesel will crank and run ok but when the transmission is shifted into forward or reverse, after about 2 minutes at any rpm, something siezes and it kills the engine. Shift into neutral and the engine recranks immediately and it will run indefinately. I first repacked the stuffing box....no help. Then I removed the transmission and sent it off for overhaul...no help. Today I dove on the boat to check the prop/shaft and found it clean with no lines or debris.
When running in gear there is a high-pitched squeel 2-4 seconds before it siezes the engine. If anyone has ever experienced this please let me know how you solved the problem. My current next move is to have the boat hauled and do a visual check of the cutlass bearing while the shaft is turning. Any help/suggestions will be greatly appreciated.
