Hello,
I noticed that my engine seems to be running hot all of the sudden. I have a 2QM15 fresh water cooled that also goes through my hot water heater. It's hard to tell what temp it is running, it's over easily 200F and maybe close to 220F but under 240 F. I don't get an alarm.
As background, I just bought the boat and my to do list is being worked on but there are some engine things that haven't been done yet. I read through two Nigel Calder books today but they didn't really seem to point me in the right direction, or at least the silver bullet wasn't identified.
I replaced the impeller on the raw water side today since the PO didn't know when it was last replaced, the old one was a little worn but not that bad and doesn't seem to be the culprit. It needed replacing anyway so no big deal.
The oil level is good, but I haven't done an oil change yet, I think I will do this next, though I don't suspect this will be the problem, but it's needed anyway.
That leaves me with the fresh water cooling side. I have not seen any leakage anywhere. I removed the freshwater cap (radiator cap thingy) and fluid came out but I suspect only due to being below the reservoir. I had to stop at this point because it was getting dark and I was getting tired, but now can't stop thinking about it.
I am almost sure that there is some issue in the fresh water side. How do I know if it is working properly other than temp gauge? I am sure that I need to replace the coolant in the engine, so I plan on that tomorrow too. When I empty it, I am considering taking each hose off one at a time to look for failure/cloggage. Is there something I should run through the system before refilling it will coolant mixture? Is there any way to know where the failure is without any leakage? I do think that the system is moving the coolant, but at a very slow rate because a lack of true overheating where I get an alarm. After the hoses, there are the cooling coils, there doesn't seem to be a way to inspect these for proper flow to determine if they are the problem. I am not in any position to replace this engine if it gets ruined and if it did our season which has started out so well, might come to a complete stop.
So, please let me know if you are "in the know" on this topic if my troubleshooting methods going forward sound logical and whether I am missing anything. I have left out thermostat because I believe that the fail open, I might be wrong though. My thoughts are that there is some sort of corrosion that happened inside the fresh water side, enough to cause a clog where a hose was bending or something and it's reducing the flow substantially, but not to the point that I get an alarm.
We've used the boat more in the last couple of weeks then it's been used in several years by the PO and when we first purchased it, at idle, the temp guage would only read around 110 F or something low like that. It is, I guess, possible that the current reading is the normal operating temp and that since the boat wasn't used, the thermostat wasn't working right, but is now and that's why it was always running cool but that seems unlikely and the current temps seem high to me.
Agian, I appreciate your insight here!
Jon
Jon
