Scott
Sound reduction attempt on a 88' Catalina 27 with an M18In an effert to reduce the engine noise that has been bothering me for years I finally tryed to do something about it.......I recently installed the sound proofing material that is in the link below and have mixed opinons about the product. I installed the material on the entire backside of front panel, the area above the engine which is the underside of the cockpit floor back about 2 feet from the front panel and the starboard side area of the engine room near the engine engine access door. After installing the material the noise has changed pitch slightly and I would say a reduction of "noise" by only 20 percent or less. Has anyone else used a product or done something differently to reduce the noise generated by the engine?
