unfortunately it might not be an quick easy fix, i have the same boat with the same engine and had the same issue, it turned out that the interior coolant passages were extremely scaled (raw water cooled engine), descaling flushes wouldn't solve the problem and I had to pull the engine and strip it down on a stand. the coolant passages in the head are fairly accessible once its removed but the passages in the block itself are narrow and deep i had to resort to a wire coat hanger to chip it all out. compressed air is the best way to clear the loose junk. the good news is its not a hard job if you dont mind taking on a project and putting the boat out of commission while you have the engine out
