Before taking everything all apart, the easy way to clear something between the raw water strainer and the outside is to disconnect the thru-hull to raw water strainer hose at the strainer, shove the bitter end into your air horn and blow the horn. If what ever is in the intake line can come out easily it will.
Brilliant! I used this technique yesterday, and it worked perfectly. Thank you!
Here's my situation. I'm moored in a tidal river, the Westport, East Branch. When it ebbs, tons of grass comes down, a lot on the surface. For 17 years with a Catalina 36, with a screen on the outside of the through-hull, I almost never picked up anything in the raw water input. Cleaned the strainer annually.
Now I have a Tartan 3800; no screen on the hull, and a Groco strainer. I can pack that strainer with grass, and sometimes small fish, in a couple of days. Yesterday the exhaust water flow diminished and I had steam while charging batts at 1,500 RPM. Cleaned the strainer, which was packed. Still no good. The through-hull goes immediately into a sharp elbow, then ball valve, then the hose to the strainer. No clearance for a sweep instead of the 90º elbow. I closed the seacock and took the hose off the strainer. Opened the seacock, only a dribble. Got the airhorn - one good blast and it was clear! Made a very satisfying burp-bubble sound. Now had a fountain of water from the hose.
Thank you again! And, despite what some say about screens, there are situations where they really, really work.
