Engine Oil Drain
1,096
CS 30 Toronto
Heat shrink a bicycle brake outer tube to the end of the plastic tube. It bends easy to reach the lowest point in the pan and won't melt in hot oil. The bicycle brake outer tube is essentially a coil spring with plastic cover. Also smaller to fit inside dip stick tube.
Sucking oil out gets about a cup more oil out than drain. Measure it next time. The oil pan has a nut welded inside for the drain plug thread. Depends on where the drain plug is, it can leave 1/4 inches of oil and sludge inside.
Oct 3, 2011
835
Those are good tips, I also wear rubber gloves to keep my hands somewhat clean...
May 2, 2012
276
Catalina 310 Toronto, Ontario
Hi alexco38 ........ I use to have Irish Rogue CS30. We talked a couple of years ago.
Cheers
2 Old Pirates
