engine descaling
rad
Has anyone evver tried CLR calcuim/lime/rust remover to decale an engine? It works wonders on plumbing fixtures. I wonder if it would work on descaling an engine? Any ideas?
Paul F
Jun 3, 2004
827
Hunter 1980 - 33 Bradenton
run in vinegar
About once a year I pump vinegar into the cooling system when going out. Turn the engine off and let it slosh around while sailing. Seems to clean the system without hurting anything.
Jun 3, 2004
232
Inside or outside?
If you have hard water deposits and crap on the lower unit you might try toilet bowl cleaner. Lysol gel does a pretty good job of eating hard water crap off the lower unit of my kicker when I take her home for the winter...
Ross
Jun 15, 2004
14,693
Go to a plumbing supply shop
and get the stuff they sell for descaling boilers. Stop fooling around with this homeowner crap.
Dec 2, 1999
15,184
Marsolve
Rad: Look for Marsolve. It is suppose to be the best stuff around. It is something the military used.
rad
marsolve unresponsive
Have tried repeatedly to get i touch with Marsolve to no avail. Too bad - sounds like a great product If we did not ask what was beyond the edge of the ocean we would spend eternity thinking the world was flat.
Dec 2, 1999
15,184
I think someone took over the product.
Rad: I think someone may have taken over the company. This appears to be the same product. http://www.rydlymemarine.com/index.html RydLyme Marine
rad
Thanks Steve
Thanks Steve for your help. I'm sure this is the same product. I'll give it a try.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Scale removal
Don't screw around with home stuff as someone else said. Get some muriatic acid, take the intake hose loose at the strainer, ( don't forget to close the seacock ) and suck two gallons of muriatic into the engine. Let it stand for five minutes, reconnect the hoses and flush it out. Works like a charm, saves a lot of labor, and won't hurt a thing.
