Aloha
83 Hunter 34. Perfect running 3GMF Yanmar. Was sailing off a mooring ball, under sail. No motor running. Had an emergency decision to make due to a friends wrong decision. There was zero time to get down and turn the water intake valve open. By the time i was in control and somewhat out of harms way I then remembered in the chaos that I was not pushing water threw the motor.
The motor was run for about 3 min only on coolant.
THAT WAS ISSUE ONE.
Sailed with motor off for about 2 hours.
Then started motor with valve open. Ran fine. No smoke , smell , water flowing.
// Not sure if i damaged anything yet// just back from the trip
+++SECOND ISSUE===
Upon docking on the the next early morning on sunrise , i took my eye off the depth gauge. I sail into an extremely shallow creek where the boat is docked.
Ran her into the mud.
I did not reverse nor put more pressure by throttling up. I was at a low rpm. I felt the boat sludge threw.
I then noticed immediately a big bellow of Thick Black smoke from the exhaust.
Again not sure of the damage yet.
But i did notice what looked like black particle coming from the water line out the back.
Im thinking I sucked the black mud threw the water box intake ?
Shes not pissing water as well as she use too ?
ANy leads on where i should look and diagnose ?
Cheers
THAT WAS ISSUE ONE.
+++SECOND ISSUE===
Cheers
