electrolytic corrosion
splax
Nov 12, 2012
694
Hunter 34 Portsmouth
I hauled out to paint and have discovered extensive pitting on the iron keel. I had remarked to those pulling the boat how good the shaft zinc looked. It seems the keel is used as the negative bus. Any suggestions for a more appropriate arrangement to stop the keel corrosion?
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
My guess is the keel barrier coat failed. Same thing happened to my Hunter 46 due to lack of maintenance by the seller. Yard sanded the entire keel to remove corrosion products and pitting to bare metal, then applied 5-7 coats of epoxy barrier cost then antifouling paint.
Aug 26, 2007
282
Hunter 41DS Ventura, California
Splax,
I'm no expert but here's what I have learned from my experience:
"Sacrificial" zincs are on the bottom of the nobility scale so if installed correctly should be the first to go. The fact that yours is in good condition would indicate that that is not the case. Building a protective system is a complicated issue (Nigel Calder's Boatowner's Mechanical and Electrical Manual has a fairly extensive chapter on this).
I would recommend hiring a marine electrician with a thorough knowledge of galvanic corrosion to check your boat.
I had the same issue that destroyed my 18" 3 blade bronze prop in a couple of weeks. After it was finally cured, I bought a galvanic corrosion meter/ tester and now check my boat monthly. Marine Digital Corrosion Tester - Seaguard International
If you decide to buy this tester, spend the extra for the Pro model or you will be replacing the anode later.
Good Luck!
JamesG161
Feb 14, 2014
7,931
Hunter 430 Waveland, MS
You cannot mount a Zinc big enough to stop galvanic corrosion on your keel.
You must barrier coat it to prevent the galvanic coupling, but it should still remain the grounding on your boat.
Grounding and Galvanic Corrosion are different things.
Jim...
Likes: sail sfbay
Feb 21, 2013
4,638
You might the following article helpful in understanding galvanic corrosion of a lead keel and repair plan . My two cents..........maintain an adequate barrier coating between the keel and high copper antifouling paint, keep the keel clean and regularly inspect the antifouling paint over it for signs of paint thinning.
Likes: JamesG161
splax
Nov 12, 2012
694
the 34 has an iron keel
