After much frustration, I finally found out how to insert a new wire. There are 4 holes visible in the WAGO blocks, one for wire, one for a tester, and one for inserting a small screwdriver to release the spring clamp inside so that the wire would go in. I used a slot next to the wire insert point (not visible in photo) to insert small screwdriver, then inserted the wire and removed screwdriver.
